Setting up 3 rb951ui-2hnd with one SSiD
The setup is as follows: Draytek 2860ac router with 3 rb951ui-2hnd APs connected to the router with hard wired cables. I simply want to have one ssid across all APs so mobile devices switch between APs seamlessly when moving from room to room, handing off from one to the other, using whichever one has the best signal strength.
I am new to Mikrotik and I am really struggling! Can anyone give me some pointers? Thank you…
