Hi all,
sorry for the rookie questions, it´s the first time configuring/using that. My purpose: setting up a hotspot guest login separated from LAN on a RB751G-2HnD on v5.23
I get a DHCP IP on my client, i can log in, but always have time outs no response whatsoever, from the boards terminal, i can ns lookup, but nothing comes back from the internet. Can please someone help, i am sure it´s a dumm rookie mistake, here some exports:
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.0.1 scope=30
target-scope=10
/ip firewall export
feb/18/2013 13:52:42 by RouterOS 5.23
software id = K7GX-7ZAC
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=
10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s
udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here"
disabled=yes
disabled=yes to-addresses=0.0.0.0
add action=masquerade chain=srcnat comment="masquerade hotspot network"
disabled=no protocol=tcp src-address=10.5.50.0/24 to-addresses=0.0.0.0
add action=masquerade chain=srcnat disabled=no out-interface=ether1-gateway
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
Do you need more exports, better which one do you need?
Thanks in advance to every suggestion!!
