Setting up a repeater
I have a wireless network and I need to extend it. The problem is that the AP that I want to extend is a basic Linksys ADSL Router (WAG160Nv2).
My “extender” is a RB433 with 2 WLAN cards. My idea was to set one of them as a client and the second one as an AP and then create a simple bridge between them. But when I connect to the extended AP I don’t get any IP address from the DHCP server running on the Linksys router. So I guess my ideas is bad. So is it possible to extend it somehow? I need to use Windows printer sharing and some LAN applications.
You need to use pseudo station.
I had to use the station pseudobridge clone, but it works!
Thanks :slight_smile:
