You need to bridgeeee, and i will show you howwww … Its really simple so dont get in a bunch. Simple go to the bridge section, hit hit the add button. pretty much leave it as it and hit ok, (It sets itself up almost) Once your bridge is created click on the “ports” tab This is the INTERFACES that needs to be bridge, This is also very simple, simple hit the + button again, dont change anything else just go down to the interface or whatever it is called and select wlan1 or your wireless interface, then hit OK. Then you are going to add another port, however this port will be ether1 or whatever your ethernet is. THIS SHOULD work!!! So good luck! let me know how it goes. -Jordan
Dosent sound right to me. however i am not familair with station just ap-bridge. But give what i said a try when you do get near your routerboard. good luck -Jordan
Can you provide a bridge export and port export, or pictures, i need information because i beleive you are doing something wrong. briding the interfaces should work.. are you sure you have internet through your wireless connection? hmm Posting information will help! Anyways post your configs of bridge -Jordan
Hi Jordan ;
i would like to ask if it is possible to make a bridge between wlan1 in the MikroTik OS and more than one repeater AP ?
i also read before that is not possible to bridge wlan to AP while wlan in station mode .
waiting your reply .
with regards
Your bost is not quite clear in what you are trying to accomplish, IF you are trying to setup a repeater AP there are many things you can do, you do not need to setup a bridge, just between the interfaces you whish to be married, what wlan1 knows ether1 knows IF You bridge them, If you have internet going into ether1 and it is bridge to wlan1 then wlan1 will have internet… ANd yes you bridge wlan and your ether port if your setting your mikrotik router in a station mode or CPE< If i have errored in what i am trying to point out please be more precise on what you need to know? thanks -Jordan
you can add more ports into the ports section of your bridge, and they will all be married.
Hi Jordan ;
Thanks for your fast reply and i will like to give you more information about what i wish to do .
first my MT wlan1 port act as AP bridge to supply wireless client with internet coming from ethernet .
wlan1 have internet and passing the internet to client without any problem
i need to connect many repeater AP in different plances arround me to do like roaming .
what i did first to setup the first AP as repeater for the wlan , it didn’t work .
activate the WDS in the wlan setting , the repeater still not working then i add a WDS to the wireless interfaces and also not working .
and as you know when you add a WDS , a new interface come in the interfaces table and i read about the bridging process , then i add bridge1 and add ports to this bridge which they are wlan1 and wds .
now the repeater working with the wlan1 and i connect the laptop to the first repeater AP by wireless connection .
everything is fine now , and when i turn off the repeater AP the laptop connect directly to the Wlan1 while the wireless work as roaming .
but
when i tried to add another repeater to the network , as above i add a new WDS and a new bridge2 and start adding the ports to it then a message telling me that wlan1 is already active with another bridge which it bridge1 .
and when i tried to add wds2 to bridge1 , it didn’t work maybe the problem with the micronet AP .
i will keep trying with another AP to see if it will work or not .
with best regards
OK that post helped alot! Now i know your using WDS< and trying to achieve roaming.. When you add a the bridge, it should be bridge1 not any other bridge, as far as i know making WDS< you create a interface called wds, set a Mac address, set the master interface which would be wlan1, and on your Repeater AP, you do the same except the Mac address there will be the mac address of station 1. that should connect the 2, However i have seen problems were you could set it to AP-bridge, and had to be a station./ Which is not correct because it should be set to ab-bridge and still make the connection using the WDS interfaces added…
However i do not use this type of repeater mode, however i am a WISP you are probibly a hot spot, or trying to cover a large area and want to roam with your laptop without being disconnected. Kind of like cell towers.
Ok i re read your post. so your on AP2 OK< now your on AP3 and your having issues… I do not see why you are messing with bridging, there is no bridging needed on AP2 Because it comes in wirless and goes out wireless, So you simple create another interface on AP3 type in the MAC of AP2.. and select master interface just like AP2.. This should work… if not please post back .. -Jordan
MT 1 (Wlan1/AP Bridge WDS) ↔ MT 2 (Wlan1/ AP Bridge WDS) ↔ MT 3 (Wlan1/ AP Bridge WDS)
on each MT, I setup Bridge with member port Wlan1 and WDS static
All WDS status on ech MT is Running Active
MT 1 :
DHCP Server, Pool : 1.1.1.100-1.1.1.150
IP Bridge : 1.1.1.1
When my Laptop using wireless connect to MT 2, I can get IP 1.1.1.149 (from DHCP) and I can ping to 1.1.1.1
But, when my laptop connect to MT 3, I can get IP 1.1.1.149 (from DHCP) buat I can not ping to 1.1.1.1
