As per the instructions on the wiki (http://wiki.mikrotik.com/wiki/Metarouter) I managed to get OpenWRT trunk up and running as a metarouter on an RB450g.
In my eventual setup, I want the host RouterOS to be basically invisible. Anything plugged in sees a router running OpenWRT, and the metarouter handles all traffic.
If I understand correctly, I need to create five virtual interfaces (vif1 to vif5), and five bridges (bridge1 to bridge5). Then, I need to bridge each real interface to each virtual interface (vif1-bridge1-ether1 etc…)
My virtual interfaces:
[admin@MikroTik] /metarouter interface> print
Flags: X - disabled, A - active
# VIRTUAL-MACHINE TYPE STATIC-INTERFACE VM-MAC-ADDRESS
0 A OpenWRT dynamic 02:16:06:4F:9A:77
1 A OpenWRT dynamic 02:0B:3E:55:A6:23
2 A OpenWRT dynamic 02:44:FF:4A:94:9A
3 A OpenWRT dynamic 02:9B:5A:38:F1:01
4 A OpenWRT dynamic 02:AE:9B:0C:F8:30
My bridges:
[admin@MikroTik] /interface bridge port> print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 I ether1-gateway bridge1 0x80 10 none
1 vif1 bridge1 0x80 10 none
2 ether2-local bridge2 0x80 10 none
3 vif2 bridge2 0x80 10 none
4 I ether3-local bridge3 0x80 10 none
5 vif3 bridge3 0x80 10 none
6 I ether4-local bridge4 0x80 10 none
7 vif4 bridge4 0x80 10 none
8 I ether5-local bridge5 0x80 10 none
9 vif5 bridge5 0x80 10 none
The problem is that OpenWRT only sees one of the virtual interfaces. Interestingly enough (according to the MAC address), it sees the second one I added, not the first:
root@OpenWrt:/# ifconfig
br-lan Link encap:Ethernet HWaddr 02:0B:3E:55:A6:23
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:1 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:696 (696.0 B) TX bytes:403 (403.0 B)
eth0 Link encap:Ethernet HWaddr 02:0B:3E:55:A6:23
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:696 (696.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:16 errors:0 dropped:0 overruns:0 frame:0
TX packets:16 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:996 (996.0 B) TX bytes:996 (996.0 B)
I’m not sure where to go from here, but any help is greatly appreciated.
