Setting up as access point
I just got a RB2011UiAS-2HnD-IN that I want to set up as an access point. My current setup is like this: modem → ASUS router → switch → my computer. I want to connect the RB2011 to the switch so I have more wifi coverage at home. What are the settings I should use? In WebFig v6.17 Quick Set, I selected Home AP from the drop down. I changed the wifi name and password. However I’m not sure what settings to use for local network. Do I enable DHCP server if my ASUS router is already doing that? Also what do I set as the IP address? The default is 192.168.88.1, but my ASUS router and all my wifi devices are in the 192.168.2.* range. Also should I enable UPnP? By default it’s off, but it sounds important. Thanks for your time.
