Setting up as home router with pppoe
Hi folks
First day with a hap ac lite. I'm trying to use it as a home router with an ISP that we connect to via pppoe. I've managedmake it work as an access point hanging off the hardware we're retiring, and can set up the pppoe client okay, but can't get traffic flowing from hosts on the home network to the internet.
I've tried to add the pertinent info here:
[admin@MikroTik] > /ip route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 217.32.145.0 0
1 ADC 192.168.88.0/24 192.168.88.1 bridge1 0
2 ADC 217.32.145.0/32 86.185.99.131 pppoe-out 0
[admin@MikroTik] > /ping 8.8.8.8
SEQ HOST SIZE TTL TIME STATUS
0 8.8.8.8 56 55 13ms
1 8.8.8.8 56 55 13ms
sent=2 received=2 packet-loss=0% min-rtt=13ms avg-rtt=13ms max-rtt=13ms
[admin@MikroTik] > /interface pppoe-client print
0 name="pppoe-out" max-mtu=auto max-mru=auto mrru=disabled interface=ether1
user="bthomehub@btbroadband.com" password="*" profile=default keepalive-timeout=60
service-name="" ac-name="" add-default-route=yes default-route-distance=0 dial-on-demand=no
use-peer-dns=yes allow=pap,chap,mschap1,mschap2
[admin@MikroTik] > /ip firewall filter print
0 chain=input action=accept protocol=icmp
1 chain=input action=accept connection-state=established
2 chain=input action=accept connection-state=related
3 chain=input action=drop in-interface=ether1 log=no log-prefix=""
[admin@MikroTik] > /ip firewall nat print
0 chain=srcnat action=masquerade out-interface=ether1
0 8.8.8.8 56 55 20ms
1 8.8.8.8 56 55 18ms
2 8.8.8.8 56 55 20ms
sent=3 received=3 packet-loss=0% min-rtt=18ms avg-rtt=19ms max-rtt=20ms
[admin@MikroTik] > /ping www.google.com
0 209.85.203.104 56 43 28ms
1 209.85.203.104 56 43 28ms
2 209.85.203.104 56 43 28ms
sent=3 received=3 packet-loss=0% min-rtt=28ms avg-rtt=28ms max-rtt=28ms
Is there anything obviously wrong here? Or anything that'd be useful to see / setup to help diagnose further.
Do U have NAT enabled for pppoe connection?
Отправлено с моего iPhone используя Tapatalk
Hi, I have this in the config:
[admin@MikroTik] /ip firewall nat> print
0 chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
which I got from RouterOS - RouterOS - MikroTik Documentation
Does this seem reasonable?
Full config here:
/export
mar/12/2017 13:42:05 by RouterOS 6.38.5
software id = 6D1C-LP83
add name=bridge1
add add-default-route=yes dial-on-demand=yes disabled=no interface=ether1 name=pppoe-out password=*
use-peer-dns=yes user=xxx@xxx.xxx
/interface wireless
set [ find default-name=wlan1 ] country="united kingdom" mode=ap-bridge wireless-protocol=802.11
set [ find default-name=wlan2 ] country="united kingdom" mode=ap-bridge wireless-protocol=802.11
/ip neighbor discovery
set ether1 discover=no
/ip hotspot profile
add name=dhcp ranges=192.168.88.0/24
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.254
add name=dhcp_pool2 ranges=192.168.88.2-192.168.88.254
add address-pool=dhcp_pool2 disabled=no interface=bridge1 name=dhcp1
add bridge=bridge1 interface=wlan2
add bridge=bridge1 interface=wlan1
add address=192.168.88.1/24 interface=ether2 network=192.168.88.0
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=ether1
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge1 type=internal
/system clock
set time-zone-name=Europe/London
/system routerboard settings
set init-delay=0s
/tool mac-server
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
add interface=wlan2
add interface=wlan1
/tool mac-server mac-winbox
add interface=wlan2
add interface=wlan1
NAT rule should be applied to pppoe-out and not to ether1. When you connect via PPPOE to your ISP, pppoe-out is now your WAN interface not ether1 anymore. So that, any firewall rule you may write from now regarding wan interface should use pppoe-out and not ether1.
Into IP → Firewall → NAT tab change out interface from ether1 to pppoe-out.
to
0 chain=srcnat action=masquerade out-interface=pppoe-out log=no log-prefix=""
Hope it helps.
kind regards,
Awesome! That does the trick. Thank you for the help here, much appreciated.
mrzipf
You did change this as well, didn’t you?
add action=drop chain=input in-interface=pppoe-out
Thanks for flagging this, I’ve got that as #0 rule now.
It’s been great getting all the help here today, everyone’s input has been super helpful. There’s a bit of a steep learning curve with the gear, but I’m pretty excited about it.
Best regards
mrzipf
