I’ve done quite a bit of searching around and I am probably just not searching for the correct thing. This seems like a newbe problem to me.
There is actually more to this problem, but I think that I have it narrowed down. I am doing some work with WDS but I am having no problems with WDS itself. In a nutshell, I need to make the set up the bridge device that WDS is connecting to as a hotspot.
The remote WDS router is not using RouterOS and is just a dumb repeater, so can’t run hotspot there. When I have not set up the wds bridge as a hotspot I can easily get a solid connection with no routing problems. However, when I make the bridge device a hotspot I can still connect using the remote repeater and I see the normal login page I use on my hotspot network (it’s modified and not generic), however at that point any username and password combo simply causes a “Radius Server Not Found” error. My troubleshooting indicates that packets will simply not route beyond the hotspot’s network. It will not act as a true hotspot and tunnel that traffic.
I did an experiment on the original router where I created a bridge, set it up as a hotspot and added one of my network cards as a port and I have the exact same problem. So I think I simply do not know how to set up hotspot on a bridge and get it to route correctly… I must be missing needed setup.
Are there any howtos out there on how to set up a bridge as a hotspot? The docs indicate that it can be done but I appear to be missing something that would allow this to route correctly.
