SETTING UP L2TP/IPsec.
Hello Everyone,
I’m a new user of MikroTIk Router OS. I would like to ask for your help in setting up l2tp/ipsec server in MT. I’ve followed the instruction in mikrotik wiki but still I’m getting this error when I tried to connect my laptop(roadwarrior) to my L2TP/Ipsec VPN Server. It seems that I cannot get pass the IPsec.
and here’s my config.
# may/07/2018 03:53:19 by RouterOS 6.41.2
# software id = RP46-TWEB
# model = 951Ui-2HnD
add admin-mac=E4:8D:8C:E5:76:BB auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=\
    MikroTik-E576BF wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/tool user-manager customer
set admin access=\
    own-routers,own-users,own-profiles,own-limits,config-payment-gw
/interface l2tp-server server
set enabled=yes ipsec-secret=123 use-ipsec=required
add address=192.168.88.1/24 comment=defconf interface=wlan1 network=\
    192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router.lan
    established,related,untracked
add action=accept chain=imput dst-port=1701 protocol=udp
add action=accept chain=input dst-port=500 protocol=udp
add action=accept chain=input dst-port=4500 protocol=udp
add action=accept chain=input dst-port=500,4500 protocol=udp src-port=1701
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=input protocol=ipsec-ah
    invalid disabled=yes
    disabled=yes in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid disabled=yes
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new disabled=yes in-interface-list=WAN
    ipsec-policy=out,none out-interface=ether1 out-interface-list=WAN
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/16
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/ppp secret
add local-address=10.0.0.211 name=l2tp password=123 remote-address=10.0.0.212
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set bridge disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
/tool mac-server
/tool mac-server mac-winbox
/tool user-manager database
set db-path=user-manager
Your help will be very much appreciated. Thank you so much.
Please disregard the diagram above. Please refer to my configuration. Thank you.
Two points:
  • l2tp/ipsec cannot work because of a typo in this rule:
    there is imput instead of correct input.
  • this rule is useless, you can remove it:
Come back with the result.
Hello Sindy,
Thank you for your help. I’ve got it RUNNING. I did a basic connection from ISP to MT.
Now, I’m trying to have another device in between which is Peplink. So, my tolopogy would be ISP to PEPLINK to MT. Now, I’m having another problem because I can’t get pass through the PEPLINK BALANCE 210. Have you encountered same scenario as this? You’re help will be much appreciated. Thanks.
I haven’t, but it is not clear from your description whether the problem is with Peplink not permitting the IPsec through or with its load-balancing capability.
So my first check would be to connect only one uplink to the Peplink and try that way. If it works in that case, it’s the load balancing, if it doesn’t, it’s the passthrough what prevents it from working.
Sorry for not clarifying that out. Yes, I did try only one uplink to the Peplink last 3 days ago but still I’m unable to get pass. So the load balancing is already out of the question. I think it really is the passthrough of the PEPLINK that causes the problem.
In that case, diagram the overall setup. Does the Peplink have a public IP address on its WAN interface and you are forwarding IPsec traffic to a private address of the Mikrotik on Peplink’s LAN side?
