Setting up LHG behind Hex S with access to it (and a bit more)
Hi!
I’m trying to set up 2 LHG LTE antennas behind a Hex S router and use PCC load balancing with them. At the moment breaking it all down into steps.
So I managed to achieve step 1 - I managed to get Hex S + single LHG working with LHG being connected to port 5 (PoE out) of Hex. Slowly wrapping my head around all settings, routes, firewall and such and how it works. Basically what I did was set up router using quickset to use ether1 for WAN and then transferred everything over to ether5: WAN interface list, excluded from bridge, enabled DHCP client for ether5.
Next step in my list is to make it so I can still access LHG through the router for managing it with winbox or webui. How would I approach this? Is the LTE Passthrough with extra VLAN the best way? Is it compatible with load balancing as it’s documented?
And after that I’d like to add second LHG to the setup (either through a PoE switch or PoE adapter and directly connected to the Hex, former is preferred if possible, but latter is fine too). Are there any examples of such setup, or can someone describe it at least in general, so I know the direction to go in?
Thanks!
my opinion ? … there are two ways to proceed with the issue:
1.st approach: you read the related documentation and then read forward in this forum how to get support - then you formulate a new request in here with the newly learned skills
2.nd approach: youtube yourself an old muppets-show episode and forget about all that electronic networking horse-shit
