Setting up Mangement Vlan?
I have a basic configuration trying to follow the documentation. Is there a way to get ‘dedicated’ 4 ports of management ‘network’ configured?
Should I use ‘vlan 0 untagged’ or vlan 99 example? If I use the ‘vlan99’ example, can I have a management port on a dedicated vlan without having to tag every port? Basically I just want a ‘management’ vlan for all of my devices, INCLUDING the router. So I could say plug in 5 devices and ‘get onto’ the management network.
The dedicated vlan 99 configuration looks like this is impossible. Any ideas?
Thomas
If there is no VLAN tagged traffic, configuring an IP address on the master-port would be enough to get an access from management network.
I guess my main question is if I have four vlans (management(101), inside(102), outside(103), VM(104). Master port is the SFP, with the ethernet1). I would like to have ports 1-8 in the management ‘zone’ with the ‘master’ port being sfp1.
Any ideas on how to do this?
Thomas
If you mean sfp port as a VLAN trunk port for vlan101;102;103;104, ether1-ether8 as VLAN access ports for vlan101 and also need IP from the same vlan101 on the CRS swtich, then this configuration should do it.
#create a group of ports for switching
set ether1 master-port=sfp1
set ether2 master-port=sfp1
set ether3 master-port=sfp1
#similar for other ports...
#add ingress vlan translation rule for access ports
/interface ethernet switch ingress-vlan-translation
add ports=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8 \
customer-vid=0 new-customer-vid=101 sa-learning=yes
#add tagged vlan ports to define vlan trunks. "switch1-cpu" has to be added for access to CRS IP address.
/interface ethernet switch egress-vlan-tag
add tagged-ports=sfp1,switch1-cpu vlan-id=101
add tagged-ports=sfp1 vlan-id=102
add tagged-ports=sfp1 vlan-id=103
add tagged-ports=sfp1 vlan-id=104
#add vlan interface to be able to configure IP for vlan101 on CRS
/interface vlan
add name=vlan101 vlan-id=101 interface=sfp1
add address=192.168.88.1/24 interface=vlan101 network=192.168.88.0
Thank you so much for your reply!
Just curious: how come no egress translation rules?
