Setting up Mikrotik as a Layer3 switch with VLAN tagging and routing
May be someone can advice how to correctly set up mikrotik for such network configuration and whether it is possible at all?
I want to have wire transfer speed between tagged and untagged ports in the same VLAN and access to router ip (different for each VLAN) from tagged and untagged ports.
I need to create multiple instances of VLANs with same ID and assign them to master-ports and bridges?
