Setting up MPLS Question
[admin@Hammett Farms] /mpls interface> pr
Flags: X - disabled, * - default
 #    INTERFACE        MPLS-MTU
 0  * ether9        1522
 1    ether6 - Bob's Dryer        1522
 2    Bullit        1522
[admin@Hammett Farms] /mpls interface> remove 0
can not remove default interface config
Why? I have it removed on other routers.
Newer version doesn’t allow it. Not sure what versions stopped allowing of removing the default configs.
That’s… awkward. have to downgrade just to delete something you don’t want?
You don’t have to downgrade. Defautl entries can be modified or disabled.
I am able to modify the default MPLS interface entry, but I don’t like how it is still highlighted in blue in Winbox. Any color other than black or gray draws attention from me. The terminal still has an asterisk next to it.
I am unable to disable MPLS interfaces through Winbox, but I can do so in the terminal. I’m not sure what effect that has since it isn’t reflected in Winbox.
