Hi all,
I am totally new to Mikrotik and its ways.. It is annoying the crap out of me since it is SO hard for a newbie to set up things to make it act like a “normal” router where LTE is the WAN..
Can someone give me some pointers of what i can do or best avoid doing in making this a succesfull installation?
Or did someone make the same setup and can i borrow your setup settings file? ![]()
I bought a NetMetal 5 (RB922UAGS-5HPacD-NM), a R11e-LTE mPCI card and an LTE antenna, i also bought a SIMcard of a local provider (T-Mobile).
And i wanted to set this all up to make LTE the WAN (like the physical line to the world), and make WLAN and LAN(/ETHER) my router connections like your normal home setup.
Unfortunately i cant make the LTE bridge with anything or delete the default “bridge”.
Later on i have some smaller wishes like adding a VPN, Guest network and a dynamic DNS setup so i can always remote login (ssh works but IP isn’t static
I hope things are laid out clear in order for you to understand
And awaiting responses which can help me.
Secretly im hoping for a config file i can upload and just change some names in order to make it fit here ![]()
