Hi
Need some help setting a RB750G up as a simple router.
Want one port as WAN with static IP setup.
All other ports as LAN ports.
DHCP server.
NAT.
Simple firewall.
Just as a standard Linksys or Netgear, only faster
Any configuration examples or script files available?
RB750G is shipped with default config which almost suite your needs.
Assign Public IP address to port 1 (ether1-gateway), remove DHCP client from port 1, and set default gateway.
DHCP server, masquarade, simple firewall is configured by default to ports 2-5.
Thatโs all.
and much, much better
Regards, Grzegorz.
It may be a bit trial and error if you are new to ROS. I suggest get you familiar with the config backup/restore function.
http://wiki.mikrotik.com/wiki/MikroTik_RouterOS
http://wiki.mikrotik.com/wiki/Category:Manual
Also here are some good video sources:
http://gregsowell.com/?page_id=951
http://www.tiktube.com/
Thank you for your help.
Got it going now
