You’re giving very little info. This would be easier with more details.
So let’s assume that the public IP is going to be 1.1.1.2/24, and the default WAN gateway is 1.1.1.1, with public DNS servers at 2.2.2.2 and 3.3.3.3. The LAN address is 192.168.0.1/24 and the email server has a static IP of 192.168.1.2. The WAN interface has been renamed to ‘outside’, the LAN interface has been renamed to ‘inside’.
First, assign the router IP addresses.
add address=1.1.1.2/24 interface=outside
add address=192.168.1.1/24 interface=inside
Then assign the default route
add dst-address=0.0.0.0/0 gateway=1.1.1.1
Then configure the internal DNS servers so the routers can resolve names
set allow-remote-requests=yes servers=2.2.2.2,3.3.3.3
Then configure outbound source NAT and inbound port forwarding for tcp/53,80,25,110, and udp/53
add chain=srcnat out-interface=outside action=masquerade
add chain=dstnat in-interface=outside protocol=tcp dst-port=53,80,25,110 action=dst-nat to-address=192.168.1.2
add chain=dstnat in-interface=outside protocol=udp dst-port=53 action=dst-nat to-address=192.168.1.2
Then configure firewalling so that the above ports can go through, and that the mail server itself can access the Internet without restrictions:
add chain=forward connection-state=established action=accept
add chain=forward connection-state=related action=accept
add chain=forward connection-state=invalid action=drop
add chain=forward in-interface=outside protocol=tcp dst-port=80,25,110 action=accept
add chain=forward in-interface=inside action=accept
add chain=forward action=drop
Then also configure firewall rules to protect the router itself and allow administration only from 192.168.1.0/24:
add chain=input connection-state=established action=accept
add chain=input connection-state=related action=accept
add chain=input connection-state=invalid action=drop
add chain=input in-interface=inside action=accept
add chain=input action=drop
