I am new to the mikrotiks and i am currently trying to set 2 hex s up in a test environment
I have no wan setup and want to use these has layer 3 switches
I have gone through all the guides but i can not seem to get this to work with my hp switch layer 2 switch
I have setup 2 vlans and a vrrp setup, i have connected my laptop up and a esxi host, i was a able to ping the host but now my laptop, then all of a sudden it has now dropped the connection to the host.
I believe it is a configuration issue but i don’t know what to look for
I have posted the full config as well if any one can give me advice.
add ageing-time=5m arp=enabled arp-timeout=auto auto-mac=yes dhcp-snooping=no disabled=no ether-type=0x8100 fast-forward=no forward-delay=
15s frame-types=admit-all igmp-snooping=no ingress-filtering=no max-message-age=20s mtu=auto name=GZOBridge priority=0x8000
protocol-mode=rstp pvid=1 transmit-hold-count=6 vlan-filtering=yes
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto
auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1596 loop-protect=default
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:01:BA:60 mtu=1500 name=ether1 orig-mac-address=
B8:69:F4:01:BA:60 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:01:BA:61 mtu=1500 name=ether2 orig-mac-address=
B8:69:F4:01:BA:61 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:01:BA:62 mtu=1500 name=ether3 orig-mac-address=
B8:69:F4:01:BA:62 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:01:BA:63 mtu=1500 name=ether4 orig-mac-address=
B8:69:F4:01:BA:63 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:01:BA:64 mtu=1500 name=ether5 orig-mac-address=
B8:69:F4:01:BA:64 poe-out=off poe-priority=10 power-cycle-interval=none !power-cycle-ping-address power-cycle-ping-enabled=no
!power-cycle-ping-timeout rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=sfp1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:01:BA:65 mtu=1500 name=sfp1 orig-mac-address=
B8:69:F4:01:BA:65 rx-flow-control=off speed=1Gbps tx-flow-control=off
/interface vrrp
add arp=enabled arp-timeout=auto authentication=none disabled=no interface=ether4 interval=1s mtu=1500 name=vrrp1 on-backup=“” on-master=“”
password=“” preemption-mode=yes priority=150 v3-protocol=ipv4 version=3 vrid=49
/queue interface
set GZOBridge queue=no-queue
set vrrp1 queue=no-queue
/interface vlan
add arp=enabled arp-timeout=auto disabled=no interface=GZOBridge loop-protect=default loop-protect-disable-time=5m
loop-protect-send-interval=5s mtu=1500 name=mgmt use-service-tag=no vlan-id=2
/queue interface
set mgmt queue=no-queue
/interface ethernet switch
set 0 !cpu-flow-control mirror-source=none mirror-target=none name=switch1
set 0 default-vlan-id=1 vlan-mode=fallback
set 1 default-vlan-id=1 vlan-mode=fallback
set 2 default-vlan-id=1 vlan-mode=fallback
set 3 default-vlan-id=1 vlan-mode=fallback
set 4 default-vlan-id=1 vlan-mode=fallback
set 5 default-vlan-id=1 vlan-mode=fallback
set [ find name=all ] comment=“contains all interfaces” exclude=“” include=“” name=all
set [ find name=none ] comment=“contains no interfaces” exclude=“” include=“” name=none
set [ find name=dynamic ] comment=“contains dynamic interfaces” exclude=“” include=“” name=dynamic
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=internet default-route-distance=2 name=default use-peer-dns=yes
set [ find default=yes ] authentication-types=“” disable-pmkid=no eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m
interim-update=0s management-protection=disabled management-protection-key=“” mode=none mschapv2-password=“” mschapv2-username=“” name=
default radius-called-format=mac:ssid radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no
radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none
static-algo-2=none static-algo-3=none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“” static-sta-private-algo=none
static-sta-private-key=“” static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates
unicast-ciphers=aes-ccm wpa-pre-shared-key=“” wpa2-pre-shared-key=“”
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value=“0xff$(CLIENT_DUID)”
set clientid code=61 name=clientid value=“0x01$(CLIENT_MAC)”
set hostname code=12 name=hostname value=“$(HOSTNAME)”
/ip hotspot profile
set [ find default=yes ] dns-name=“” hotspot-address=0.0.0.0 html-directory=flash/hotspot html-directory-override=“” http-cookie-lifetime=
3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list=“” idle-timeout=none !insert-queue-before keepalive-timeout=2m mac-cookie-timeout=
3d name=default !parent-queue !queue-type shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec mode-config
set [ find default=yes ] name=request-only responder=no
/ip ipsec peer profile
set [ find default=yes ] dh-group=modp2048,modp1024 dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=aes-128,3des hash-algorithm=sha1
lifetime=1d name=default nat-traversal=yes proposal-check=obey
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default
pfs-group=modp1024
add name=dhcp_pool0 ranges=10.17.121.1,10.17.121.3-10.17.121.254
add name=dhcp_pool1 ranges=10.17.121.1,10.17.121.3-10.17.121.254
add name=dhcp_pool2 ranges=10.17.121.5-10.17.121.254
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none stop-bits=1
/ppp profile
set *0 address-list=“” !bridge !bridge-horizon !bridge-path-cost !bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout
!incoming-filter !insert-queue-before !interface-list !local-address name=default on-down=“” on-up=“” only-one=default !outgoing-filter
!parent-queue !queue-type !rate-limit !remote-address !session-timeout use-compression=default use-encryption=default use-mpls=default
use-upnp=default !wins-server
set *FFFFFFFE address-list=“” !bridge !bridge-horizon !bridge-path-cost !bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout
!incoming-filter !insert-queue-before !interface-list !local-address name=default-encryption on-down=“” on-up=“” only-one=default
!outgoing-filter !parent-queue !queue-type !rate-limit !remote-address !session-timeout use-compression=default use-encryption=yes
use-mpls=default use-upnp=default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=src-address
pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128
pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set sfp1 queue=only-hardware-queue
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id !confederation disabled=no ignore-as-path-len=no name=default out-filter=
“” redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=
0.0.0.0 routing-table=“”
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id !domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20
metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 !mpls-te-area !mpls-te-router-id name=default out-filter=
ospf-out redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=
0.0.0.0 !routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=backbone type=default
/snmp community
set [ find default=yes ] addresses=::/0 authentication-password=“” authentication-protocol=MD5 encryption-password=“” encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=flash/log disk-lines-per-file=1000 disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto
syslog-time-format=bsd-syslog target=remote
/user group
set read name=read policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,sensitive,api,romon,tikapp,!ftp,!write,!policy,!dude
skin=default
set write name=write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,sensitive,api,romon,tikapp,!ftp,!policy,!dude
skin=default
set full name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
skin=default
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man manager
set ca-certificate=none certificate=none enabled=no package-path=“” require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/certificate settings
set crl-download=yes crl-store=system crl-use=yes
/dude
set data-directory=dude enabled=no
add auto-isolate=no bpdu-guard=no bridge=GZOBridge broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=
none hw=yes ingress-filtering=no interface=ether2 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10
point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes
unknown-unicast-flood=yes
none hw=yes ingress-filtering=no interface=ether5 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s
tcp-time-wait-timeout=10s tcp-unacked-timeout=5m udp-stream-timeout=3m udp-timeout=10s
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes
max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=yes send-redirects=yes tcp-syncookies=no
/interface bridge vlan
add bridge=GZOBridge disabled=no tagged=mgmt untagged=“” vlan-ids=2
/interface detect-internet
set detect-interface-list=none internet-interface-list=none lan-interface-list=none wan-interface-list=none
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2 caller-id-type=ip-address default-profile=default-encryption enabled=no
ipsec-secret=“” keepalive-timeout=30 max-mru=1450 max-mtu=1450 max-sessions=unlimited mrru=disabled one-session-per-host=no use-ipsec=
no
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=FE:77:C3:26:20:D3 max-mtu=
1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=
disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=default enabled=no force-aes=no keepalive-timeout=60 max-mru=
1500 max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses=“” caps-man-certificate-common-names=“” caps-man-names=“” certificate=none discovery-interfaces=“”
enabled=no interfaces=“” lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.17.121.2/24 disabled=no interface=ether4 network=10.17.121.0
add address=10.17.121.1/32 disabled=no interface=vrrp1 network=10.17.121.1
add address=10.17.121.1/24 disabled=no interface=mgmt network=10.17.121.0
/ip cloud
set ddns-enabled=no update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-server config
set store-leases-disk=5m
add address=10.17.121.0/24 caps-manager=“” dhcp-option=“” dns-none=yes gateway=10.17.121.1 ntp-server=“” wins-server=“”
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB max-concurrent-queries=100 max-concurrent-tcp-sessions=20
max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=10s servers=“”
add action=masquerade chain=srcnat !connection-bytes !connection-limit !connection-mark !connection-rate !connection-type !content
disabled=no !dscp !dst-address !dst-address-list !dst-address-type !dst-limit !dst-port !fragment !hotspot !icmp-options
!in-bridge-port !in-bridge-port-list !in-interface !in-interface-list !ingress-priority !ipsec-policy !ipv4-options !layer7-protocol
!limit log=no log-prefix=“” !nth !out-bridge-port !out-bridge-port-list !out-interface !out-interface-list !packet-mark !packet-size
!per-connection-classifier !port !priority !protocol !psd !random !routing-mark !routing-table !src-address !src-address-list
!src-address-type !src-mac-address !src-port !tcp-mss !time !tls-host !to-addresses !to-ports !ttl
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment=“counters and limits for trial users” disabled=no name=default-trial
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=all src-address=::/0 template=yes
/ip ipsec user settings
set xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no
max-cache-object-size=2048KiB max-cache-size=unlimited max-client-connections=600 max-fresh-time=3d max-server-connections=600
parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no src-address=::
/ip service
set telnet address=“” disabled=no port=23
set ftp address=“” disabled=no port=21
set www address=“” disabled=no port=80
set ssh address=“” disabled=no port=22
set www-ssl address=“” certificate=none disabled=yes port=443
set api address=“” disabled=no port=8728
set winbox address=“” disabled=no port=8291
set api-ssl address=“” certificate=none disabled=no port=8729
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=all
/ip smb shares
set [ find default=yes ] comment=“default share” directory=/flash/pub disabled=no max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password=“” read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set always-allow-password-login=no forwarding-enabled=no host-key-size=2048 strong-crypto=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=64k enabled=no inactive-flow-timeout=15s interfaces=all
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes
icmp-type=yes igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes ipv6-flow-label=yes is-multicast=yes
last-forwarded=yes nat-dst-address=yes nat-dst-port=yes nat-src-address=yes nat-src-port=yes out-interface=yes packets=yes protocol=yes
src-address=yes src-address-mask=yes src-mac-address=yes src-port=yes tcp-ack-num=yes tcp-flags=yes tcp-seq-num=yes tcp-window-size=yes
tos=yes ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1
redistribute-bgp=no redistribute-connected=no redistribute-ospf=no redistribute-static=no routing-table=main timeout-timer=3m
update-timer=30s
/snmp
set contact=“” enabled=no engine-id=“” location=“” trap-community=public trap-generators=temp-exception trap-target=“” trap-version=1
/system clock
set time-zone-autodetect=yes time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end=“jan/01/1970 00:00:00” dst-start=“jan/01/1970 00:00:00” time-zone=+00:00
/system console
set [ find port=serial0 ] channel=0 disabled=no port=serial0 term=vt102
/system identity
set name=MikroTik
/system leds
set 0 disabled=no interface=sfp1 leds=sfp-led type=interface-activity
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix=“” topics=info
set 1 action=memory disabled=no prefix=“” topics=error
set 2 action=memory disabled=no prefix=“” topics=warning
set 3 action=echo disabled=no prefix=“” topics=critical
/system note
set note=“” show-at-login=yes
/system ntp client
set enabled=no primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0 server-dns-names=“”
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
/system resource irq rps
set ether1 disabled=no
set ether2 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
set sfp1 disabled=no
/system routerboard settings
set auto-upgrade=no baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet boot-protocol=bootp enable-jumper-reset=yes
enter-setup-on=any-key force-backup-booter=no protected-routerboot=disabled reformat-hold-button=20s reformat-hold-button-max=10m
silent-boot=no
/system routerboard mode-button
set enabled=no on-event=“”
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=“”
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m ping-timeout=1m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> password=“” port=25 start-tls=no user=“”
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
set allowed-interface-list=all
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00 secrets=“”
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all secrets=“”
/tool sms
set allowed-number=“” auto-erase=no channel=0 port=none receive-enabled=no secret=“” sim-pin=“”
/tool sniffer
set file-limit=1000KiB file-name=“” filter-cpu=“” filter-direction=any filter-interface=“” filter-ip-address=“” filter-ip-protocol=“”
filter-ipv6-address=“” filter-mac-address=“” filter-mac-protocol=“” filter-operator-between-entries=or filter-port=“” filter-stream=no
memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=no stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups=“” interim-update=0s use-radius=no
Kind Regards
M Rose
