Dear Sir,
( Here WiMax is consider as Free Freq. )
We are looking for solution where we have one base station which have fiber as back haul, which can have some good traffic capacity & customer carry one CPE at there end, which is in LOS or NLOS which can communicate with base station & get the require bandwidth , which start from 128kbps to 2mbps continues connectivity, can you please suggest us which is of product is best & what is its cost, send us product datasheet & price points.
We are looking for End to End solution from the vendor, we had tried with different vendor , they are from RF also as well they are from WiMax also,
We have no bar on technology part, we need solution which can either on RF or on WiMax, but we prefer to get the solution for both as we have some areas where we can cover those customer on RF & we have some area where we have customer where we can connect them on WiMax,
- We have area of 20KM where we can setup Wimax
- we have some area of 5KM where we can use RF
- More over that we have certain requirement of Point to Point as well Point to MultiPoint, if you can arrange some demo as well if you arrange your eng to visit at our place with all your Strong Product offering then we can move ahead on this.
Our AIM is to setup one base station where multiple customer send request via there CPE ( Customer Premises equipment)
Can you suggest the best possible hardware to setting up the same,
Also we like to supported CPE with Mikrotik base stations.
