setting up wireless adapter
Heloo all, I have wireless adapter Pheenet Atheros 54g, I put it to router, and only that’s happend was to mikrotik just loaded driver for atheros AR5212 PCI. What is the next? How to setup IP address, how to see adapter in interfaces LIST? On interface list I only have 2 Ethernet Card’s, one public, one for LAN. Using MT 2.9.27
Can enyone help me?
I’m new user of MT, but for a week, I have set up, dhcp, proxy and everything else for lan-internet. I used forum,wiki, and user manual.I found everything i need exept answer for my question above. So… Im noob :blush:
Thanks all
If you do not see wlan adapter in interfaces then it doe snot work. It is possible that your motherboard does not support such card. What motherboard do you have? Is it PCI 2.1?
Tonight, there was a Server crash… unable to… bla bla
Before new install, I put wireless adapter, start new install, and restore beckup (10min of job)
Then when i entered in to interfaces, now i can see adapter and it’s working.
Celeron 466mhz 256ram ( i think it’s PCI 2.1)
Now everything working fine, but still don’t undersand how install set w. adapter, and manualy i couldn’t? I’m confused myself right now.. sorry
You have IRQ problem.
Try to put one card at a time in PCI slot. I mean put one card, turn on comp, turn off, put second card turn on. . … ..
