Setting web browser parameters
I’m running Dude ver 4.0beta3.
Unfortunately Firefox (my default web browser) decided to update itself to ver 5.
Now I can’t manage my UBNT devices by clicking tools - web.
Is there a way to tell Dude to use IE, Chrome or Safari instead of the browser that’s set as default in the system?
Thank you
Eben
You can ammend the web settings to run the following command(keep the “” marks):
“c:\program files\internet explorer\iexplore.exe” [Device.FirstAddress]
This will launch Internet explorer and then go straight to the page you require.
IE tab is a nice add on for firefox it lets you run IE in a tab… as it sounds.
Any site you tell to open in an IE Tab will use iexplorer. Also if needed turn off version checking for plugins.
http://www.bluishcoder.co.nz/articles/mozilla/disable-extension-check.html
https://addons.mozilla.org/en-US/firefox/addon/ie-tab/
