I am try to send syslog to proxylizer server , while setting the web proxy error
“Web-Proxy error : port 8080 already in use” is echo’d in system log.
RouterOs Version 2.9.6
only 8080 port I am using to set up proxy .
Can any one help me?
post output of this command:
/ip services print
I like to know which RouterOS version does support proxyliser.
Thanks Normis.
u have /ip proxy and /ip webproxy
make enabled webproxy and desabled proxy. maybe this is the solution.
you need to upgrade to v4.16
the upgrade is free, if your license is legitimate
My client is using v4.6,
For testing purpose I am using v2.9.6 ,
Is there a possibility for proxylizer working with v2.9.6 ?
Thanks to all ![]()
yes, proxilyzer can work with v4.6, maybe it will even work better than v2.9
