Reading through more posts in the MikroTik forums, it doesn’t seem that the version 4.0b3 software is ready for prime time (hence, the “beta” in its name), so my question on that is moot.
I did re-install 3.6 on the Windows Home Server 2011 computer. When I went back in, it was, no surprise, as if I had just installed it. I had.
However, I had kept the “data” folder from my original installation… desperate move, as I didn’t have any other direction to go at the time. So, I copied it back into the “Dude” program folder.
No dice. The program came back up again as if it were brand new.
Hmmm. Not being willing to accept defeat (quite yet), I opted for a different tactic. This time, I went back to the “Dude” program folder, change the permission to give “user” full control. Again, I copied the “data” folder back into the “Dude” program folder.
Bingo! When I restarted the program, it came up with my original network map (which I had spent a lot of time building).
At that point, I exported a backup XML file… just in case.
Now I’m wondering – why was this a problem to begin with? There doesn’t appear to be any means to re-point The Dude to use a different location for the data folder, and there is no explicit “save” command… “export” is as close as it comes. No errors are thrown regarding program access permissions… it “just works”… right up to the point when it doesn’t.
Perhaps the program needs to use the “Program Data” folder off of the root (hidden folder, for anyone who is otherwise unfamiliar with it) as a location for the program data. By default, the program folder has stricter permissions, and the program data folder might be more appropriate.
Heck, I don’t even know if this is actually the problem… but I do know that at one point I had lost my data, and after the permissions change – it was back.
The program is good, though has some rough edges (for free, they’re pretty easy to overlook).
Hoping that what was related here might help somebody. Would really like to get some conversation going on this; is there some better practice to use regarding configuring the data storage for The Dude? Losing data is just hard to abide.
Pat
