ok i did some lab testin and here are some setups and resaults
setup
side a
band 5GHz A/N
Channel width 20MHz
Wireless protocol : any
bandwith test : avg total 9.6 kbs/ 4Mbs very unstable
TZ/RX Signal: -54 / -56 (its stays the same for every configuration)
TX/RX Rate: 65 mbps /65mbps (very unstable)
TX/RX CCQ : avg 50 / 50
Nstreme: enabled
side b
band 5GHz A/N
Channel width 20MHz
bandwith test : avg total 3.3 3.2 very unstable
TX/RX Rate:
TX/RX CCQ :
nstreme: enabled
side a
band 5GHz A/N
Channel width 20MHz
Wireless protocol : nv2
bandwith test : avg total 10 10.1 mbps / 10.2 Mbs it stops transmiting after a while
TX/RX Rate: 48-64 mbps / 48-64 mbps ( unstable)
TX/RX CCQ : avg 70-90 / 70-90 %
Nstreme: enabled
side b
band 5GHz A/N
Channel width 20MHz
nstreme: enabled
on bandwith test some times send and receive ok some times only receive ? i mean if i stop and start the test
side a
band 5GHz A/N
Channel width 20MHz
TX/RX Rate: 54 mbps / 54 mbps ( stable)
TX/RX CCQ : avg 50-70 / 50-70 %
Nstreme: disabled
side b
band 5GHz A/N
Channel width 20MHz
nstreme: disabled
on bandwith test after a few second only receiving ?
ok i think i got it
side a
band 5GHz A/N
Channel width 20MHz/40MHz and above
bandwith test : avg total 24.1 mbps / 20 Mbs (stable)
TX/RX Rate: 121 mbps / 121 mbps ( stable)
TX/RX CCQ : avg 50-60 / 50-60 %
Nstreme: enabled
side b
band 5GHz A/N
nstreme: enabled
bandwith test is stable and its not stoping trasmiting after a while however i get may lost packets
ok i tryed a real world download
its seems that im able to download faster when i set wireless protocol on both end to : any but when i test the links with winbox bandwith tester i get very low speeds
if i set the point a wireless protocol to nv2 i get very high bandwith output on windox bandwith meter but lower download speed
any clue?
