Setup a wlan adapter - station mode
I have a RB711UA device here - goal is to just connect to WLAN And forwrd ip to client connected with cable.
Got i working so the device is connected to the WLAN - now i only need to setup so WLAN is forwards IP to all clients connected to its eth1 port.
How do i do this? probably something simple… i have tried testing with different bridge settings but not getting this to work..
would gladly pay for help /advice,
thanks for help,
best regards,
Johan
Set the wlan1 mode as AP-bridge.
Create an interface bridge.
In the bridge add wlan1 and the eth1.
Now you wlan clients are virtaully connected to the eth1 as it was a switch.
Thanks Rodolfo testing Tomorrow first thing after coffeee.. .
Best regards,
Johan
