Setup dns-update with simple DNS
I am running a simple DNS server. Inside Simple DNS we can allow dynamic updates via a key-name and key-value. In the RouterOS there is the “tools → dns-update”… I created a key-name and key-value on my DNS server and it doesn’t seem to like it, I keep getting the “bad key” error.. I have copy an pasted the key-value 4 or 5 time with different keys and non of them work…
Here is my command:
dns-update dns-server=“10.0.0.6” address=“10.0.0.10” key-name=“username” key=“oV7YagF3NAZsCgUX/d1s9Q==” name=test zone=internal.local
error msg: bad key
I know it is getting to the server because if I change the “dns-server” ip I get “connection timeout” error.
Has anyone successfully done this?
Thanks…
are the times synced ?
Yes, they are within 1/2 a second of each other. Why does that matter?
