Hi , i need to set up a connection to an apartment, each user will have a diffrent user name & pass for hotspot, when i connect to base via 133c and try to distrubute the connection with switch , laptops get the ip address but there is no internet. can someone help me out of this ??
From the description it sounds like a NAT issue, but if you want more help you need to describe your situation better. Services you are running on the router board.
Do you get the hotspot page?
Can you log in?
Can you ping the router?
Can you do a DNS lookup?
Can you trace route to the internet?
-Louis
louis , i can do the things you ask when i plug the cable from rb into one computer. there is no problem with the connection, i thing what im doing wrong is the distrubiting part.
still no solution. ![]()
You need to post your configuration.
found the solution, switch works as expected but the problem was the connection. thanxx
