setup hap lite wifi
Hi
I have an existing network with wifi, I would like to put the hap lite in the attic which does not have a lan cable, to recieve a wifi network and then use the ports to provide network access for devices which dont have wifi built in to them. can anyone guide me how to setup the hap lite to be able to achieve this? many thanks for any help provided.
have you thought of using moca adapters (existing cable wiring) or powerline adapters (using existing electrical wiring)?
I have used this post, sure it can help you:
https://www.justinho.com/blog/2017/07/15/hap-ac-lite.html
Thank you for your reply, I am not wanting to use it to broadcast any wifi rather to recieve network connection via wifi and then only use lan ports to provide network access?
have tried them in the past and have never found them to be reliable for to host a server on the other end of the connection.
So…then don’t configure that part.
The post @erlinden linked is generally fine. However the setup has one drawback (which might be show stopper): it is not possible to directly access devices “behind” wireless device. As you’re mentioning server (for which powerline adapters are not reliable enough), I guess you are actually after an L2-transparent wireless link which would make wired hosts in the attic appear full members of the rest of LAN. This is not possible when talking about pure 802.11 standard because standard lacks room for 4-th MAC address. Different vendors created different work-arounds and standard extensions and are mostly incompatible. So you will have to use wireless client (in the attic) by the same vendor as AP.
Now, if your AP is mikrotik as well, then setup of hap lite is easy … but you have to do it from blank configuration:
  1. create a bridge and add all ether ports and wireless port to it
  2. configure wlan1 interface, set mode=station-bridge, configure SSID and PSK according to settings on your AP
  3. on bridge interface either set IP address statically (add default route using main router’s IP address as gateway) or set DHCP client so you’ll have admin access to hAP lite via your LAN
https://wiki.mikrotik.com/wiki/Connect_to_an_Available_Wireless_Network have used this and can access the network as required, the only problem i am having is that the lan clients are not getting the dhcp from the internal server but rather from the mikrotik dhcp router server how can i change this to use the dhcp server already on my network and to keep the clients on the same ip address pool as the rest of the network?
can you explain a little bit more please as am new the network and mikrotik and trying to get my head around all this. I use bt mesh to supply wifi around the house, and can get the mikrotik to join the network and can get the lan clients to get internet but am stuck in trying to get the client lans to be on the same network as the rest of the house.
You can read more about the problem in this article. In short: get yourself another AP by same vendor and you’ll likely get it working in short time. Use any other vendor and you’ll have problems this way or another.
