is it possible to setup a single hotspot on multiple interfaces without bridging them?
“single”? no, of course. either you use different IP subnets on different interfaces (and with different hotspot instances), or you bridge interfaces together
why do you need it?
I have install as chupaka sad, but it says authentication failed: no address from ip pool
Does the IP pool exist? Is it exhausted? Is it a different pool from your original one, which won’t work because you are on a different interface and have different IP space?
Do you actually NEED the Universal NAT feature and could you just set the pool to ‘none’?
hi chupaka
thought setting up multiple hotspot on a router may have some kind of disadvantage?
what disadvantage? =)
I run a minimum of 3 Hotspots on every router I have Hotspots on at all. No issues.
