Setup mAP as AP
I have 2 router, RB750 and mAP. I try to leases ip from RB750. so i have done this.
# nov/09/2016 21:49:20 by RouterOS 6.37.1
# software id = ZPJF-7YXC
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=auto mode=ap-bridge ssid="[wifi-next]"
/ip hotspot profile
add bridge=bridge1 interface=wlan1
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=yes use-ip-firewall-for-vlan=yes
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=bridge1 use-peer-dns=no use-peer-ntp=no
/system clock
set time-zone-name=Asia/Dhaka
/system identity
set name="RouterBOARD mAP L-2nD"
/system ntp client
set enabled=yes primary-ntp=114.130.13.6 secondary-ntp=108.61.194.85
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
Everything worikng, dhcp get ip from RB750, but I can’t access RB750 or the internet from wifi.
Maybe you forgot to set dns and default route ( rb750 ip ) ? Please define " I can’t access RB750..": can not access it on webFig, Winbox or does not respond to ping ?
Could you post here results of ( from ‘New Terminal’ of mAP ) :
/ip route print
and
/ip dns print
P.S. May i ask why do you enabled/checked ‘Use Ip Firewall’, ‘Use Ip Firewall for VLAN’ and ‘Use Ip Firewall for PPPOE’ into bridge settings ?
kind regards,
You actually not using the DNS server supplied by your DHCP server (use-peer-dns=no parameter on your dhcp-client)
add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=dhcp1 relay=172.16.10.1
this solve the issue for now. And I am using DNS, I just want client get ip from RB750 not mAP lite.
