setup mikrotik and nanostation2 antenna
Hello ALL
i have a mikrotik with a nanostation2 antena, i want to setup that,
I want to know how can i setup my mikrotik if my antenna work in mode AP to distribute the connection to the customers who have their laptop
please i wait your reply
which mikrotik device do you have exactly? how are they connected together?
i have setup a mikrotik OS 3.22 in the Desktop, and i want to connect my nanostation2 (2.4) for do the Point to multipoint with the customers that use the laptop with the wifi connexion
how can i do that please ??
thanks
If the NS is to be the AP what is the task of your PC?
If your PC running ROS is attached to an ISP by a modem or router, you probably need a second Ethernet port in your PC to connect it to the NS.
If you just want to grand internet connectivity to the NS-AP than set the ROS-PC up as bridge so NS as dhcp-client or PPoE client will get the authentication and IP address etc. from ISP.
But there are many other ways to do it. So you really need to give us more info on what your really want because basically you can setup the NS2 to connect directly to adsl-modem or router for instance.
For questions about how to setup the NS2 go to the ubnt forum.
