Hello I am currently running MT 2.9.14. I am using NAT to connect my local lan through the MT to the internet. I want to make sure I have everything setup correctly to pass IPsec VPN traffic through the MT from my local lan to the internet. I have customers that will be using VPN clients that need to connect to internet VPN servers through the MT. ALL of these clients will be using some variant of ipsec, one for example is using a cisco pix. What settings do I need to be sure to enable to allow this traffic to pass since I am using NAT at the internet endpoint MT router?
VPN client ----> router (not running NAT) —> MT (running NAT to the internet) —>Internet → VPN server
No, you should be OK provided the servers that the clients connect to support NAT-T. I run both IPSEC and PPTP through an MT with src-nat defined and it works fine using UDP encapsulation for the ESP packets.
Only exception at the moment is Cisco IPSEC over TCP port 10000. I don’t get any packets back at present but I’m still investigating this.
