Setup OpenVPN Server
HI all,
i use a hex-router on a DSL connection and try to setup a OpenVPN Server. For this i follow this tutorial https://blog.nmoleosoftware.com/index.php/2022/06/12/how-to-set-up-and-connect-to-an-openvpn-server-on-mikrotik-routeros-7/ and setup the connection.
If i try the config with a OpenVPN client on windows i need to enter usernmae/password. But the clients which should connect to the server are IoT devices without a user-interface, so i can not enter username/password. How can i setup the connection to use only certificates?
Router OS is 7.15.3
Thanks & Regards
