Setup SSH Key Issues
I have loaded the private and public key. Then try to install but get an error that the Passphrase in incorrect. Actual error is:
Couldn’t perform action - unable to load key file (incorrect passphrase?) ! (6)
Should the key files be uploaded to a specific folder?
boddy do you have a solution for the problem? I am in the same problem
