Hi and thank you for your help.
I am trying to setup my hap ax3 as router and wifi access point.
It should be connected to a managed switch, where my ethernet devices are connected to.
The ports on the mikrotik should just be used for WAN and the Trunk to the managed switch for now.
I started with the default configuration, which I then slightly modified so that I can have WAN on port 5 instead of the default port1, because I want to use the 2,5G connection between the managed switch and mikrotik.
In the Network I want to have for now 3 VLANS:
guest 10.10.0.0/16 on vlan-id 10
trusted 10.20.0.0/16 on id 20
mgmt 10.100.0.0/16 on id 100
I tried to setup things up as much as I could, and am at the point where I want to get ready to remove the default network & dhcp, so that I connect only via mgmt network from my PC to the managed switch on the vlan-id 100 access port. The managed switch is tagging 10-.20- and 100 vlans on the connection port to the Mikrotik.
I tried to set the port 1 on the mikrotik as trunk(as far as I understood), but it always disconnects me(thank you for Safe mode)
I have port 3 used as a direct connection to mikrotik now aswell.
One thing of note, between the managed switch and the mikrotik there is a POE injection device to power the mikrotik, but I hope this will forward traffic as expected.
Unfortunately only the 2,5G port is POE-in.
The problem is now, that I apparently did not configure the VLANs/Trunk correctly, because I can't connect to the Mikrotik from my pc via the Mgmt network.
I will paste my config in here, cutting out some details about the wifi:
# 2025-11-09 20:22:34 by RouterOS 7.20.4
# software id = IK1E-8R5L
# model = C53UiG+5HPaxD2HPaxD
# serial number = ------
add admin-mac=D4:01:C3:44:94:80 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether5 ] comment="WAN Port"
/interface vlan
add comment="Guest Vlan" interface=bridge name=vlan10-guests vlan-id=10
add comment="Trusted VLAN" interface=bridge name=vlan20-trusted vlan-id=20
add comment="management vlan" interface=bridge name=vlan100-mgmt vlan-id=100
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=pool10 ranges=10.10.0.10-10.10.255.255
add name=pool20 ranges=10.20.0.2-10.20.255.255
add name=pool100 ranges=10.100.0.1-10.100.255.255
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=pool10 comment="Guest dhcp server" interface=vlan10-guests \
lease-time=1d name=dhcp10
add address-pool=pool20 comment="Trusted network dhcp server" interface=\
vlan20-trusted lease-time=1d name=dhcp20
add address-pool=pool100 comment="Mgmt Network DHCP Server" interface=\
vlan100-mgmt lease-time=1d name=dhcp100
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment="Trunk port to sodola switch" frame-types=\
admit-only-vlan-tagged interface=ether1 pvid=100
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add comment=defconf interface=ether5 list=WAN
192.168.88.0
add address=10.10.0.1/16 comment="Guest Address" interface=vlan10-guests \
network=10.10.0.0
add address=10.20.0.1/16 comment="Trusted Address" interface=vlan20-trusted \
network=10.20.0.0
add address=10.100.0.1/16 comment="Mgmt Address" interface=vlan100-mgmt \
network=10.100.0.0
/ip dhcp-client
add comment="enable dhcp client for WAN" interface=ether5
add address=10.10.0.0/16 comment="Guest Network" dns-server=1.1.1.1,1.0.0.1 \
domain=chriy.de gateway=10.10.0.1
add address=10.20.0.0/16 comment="Trusted Network" dns-server=1.1.1.1,1.0.0.1 \
domain=chriy.de gateway=10.20.0.1
add address=10.100.0.0/16 comment="Mgmt Network" dns-server=1.1.1.1,1.0.0.1 \
domain=chriy.de gateway=10.100.0.1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys \
source="\r\
\n :foreach iface in=[/interface/wifi find where (configuration.mode=\"a\
p\" && disabled=no)] do={\r\
\n /interface/wifi wps-push-button \$iface;}\r\
\n "
/tool mac-server
/tool mac-server mac-winbox
Can you please help my trying to understand what I am doing wrong?
