Is it possible to set up a VPN on your router so you don’t have to run software on multiple computers/devices? (If possible, then how?)
Updated: Thanks for your help I have found the solution related to my issue here.
I was looking into this a few days ago and ran across this. I haven’t tried it yet put it seems simple enough. I’m sure others will be along shortly to explain the correct way to do it.
https://support.safervpn.com/hc/en-us/articles/360035919413-Setup-OpenVPN-manually-on-Mikrotik-Router
How about going to actual official Mikrotik wiki and using guides from there?
Also users in Mikrotik forum posted few as well. e.g. I created this: http://forum.mikrotik.com/t/mikrotik-behind-nat-to-mikrotik-ipsec-ike2-with-certs-tunnel-eoip/144952/1 + http://forum.mikrotik.com/t/vpn-ipsec-with-strongswan/132391/1
One of the best guides online I found is from https://mynetworktraining.com/ this guy which also has all the courses on Udemy too, including setting up VPNs.
