kingen
March 16, 2012, 6:22pm
1
Ok so here is what i got:
Ethernet Cable with wan from ISP —> pluged in on Ether1 in my miktorik
adress from ISP is:
IP: 83.227.xxx.140
GW: 83.227.xxx.149
dns: 195.55.122.203
mask: 255.25.255.192
I whould like those setting applied to the Ether1 interface on my miktori, how should i do?
gcs
March 16, 2012, 6:53pm
2
what RB do you have?
If you can run winbox just click on ip on left side of screen. Then click on address. click on red + sign upper left corner. input the information you just posted and choose ether1 or what ever you call the interface.
click on ip dns and fill it in.
you may need to set up routes also. ifdo it is under ip on left like the above.
kingen
March 17, 2012, 2:50pm
3
I have a 450G
In Miktorik it says:
Address: (my ip address) 83.227.xxx.140
broadcast: ?? what should i put in here?
Network: Is that suposed to be my GW?
kingen
March 18, 2012, 12:46pm
4
Does someone know? I think it’s verry indistinct..
need help!
IP: 83.227.xxx.140
GW: 83.227.xxx.149
dns: 195.55.122.203
is that your WAN IP? or that ip is assign by your adsl routers/CPE provided by ISP?
kingen
March 18, 2012, 1:23pm
6
That is my Static IP-adressed assigned by my adsl modem
and you want to add it in your mikrotik ether?
isnt it?
kingen
March 18, 2012, 1:56pm
8
keywords: Setup static ip wan
Ok i figured out how to get it to work this is what i did:
Added my IP-address form my ISP :
add address=83.227.135.130/26 interface=Ether1
Added a LAN address for my lan on Ether2 :
add address=192.168.0.1/24 interface=Ether2
Then i added my ISPs DNS :
set servers=195.23.144.141,195.23.144.1412 allow-remote-requests=yes
Then i added DHCP server and pool to ether2 :
add name=dhcp-pool ranges=192.168.0.10-192.168.0.254
add name=dhcp interface=LAN address-pool=dhcp-pool
add address=192.168.0.0/24 gateway=192.168.0.1 dns-server=192.168.0.1
Then i created a route and added my deafult gateway from ISP :
add dst-address=0.0.0.0/0 gateway=83.227.135.129
Then i made a Firewall-NAT rule
add action=masquerade chain=srcnat comment="" disabled=no out-interface=ether1
It’s that easy, someone should have written these step-by-step guide before
Check this out!
http://blogs.infinitysolution.co.cc/
am sure you will find alot of stuff there
