Setup Wireguard behind ISP router
How can I setup “RoadWarrior” wireGuard tunnel without a public IP address? I am receiving a private IP address [192.168.88.2] from my ISP.
I’m replying to you over WireGuard configured for this very situation. :wink:
Thank you for this. Could you elaborate more on how you did the port forwarding? “Since my RouterOS box is behind another router, I forwarded this UDP port to it.”
I did this.
/ip firewall nat add chain=dstnat dst-address=192.168.1.1 protocol=tcp dst-port=13231 action=dst-nat to-addresses=10.10.10.1 to-ports=13231
where 192.168.1.1 is my local router lan ip address and 10.10.10.1 is the actual public ip address from the isp router
You don’t do the port-forwarding on the RouterOS box; you do it on the ISP router. Even if you had named it, the how-to of setting up a port-forward on it from the public WG port you picked to the RouterOS box behind it answering the WG connection would be off-topic here. That’s why my guide links you to this generic port-forwarding guide.
Thank you. Worked like a charm!
