I just setup NextDNS on MK router. What I need to do in order to setup on the router for my WG clients to use it?
Are you saying next dns provides wg services?
I’m guessing OP wants that wg peers use NextDNS as resolver when connected.
But not sure what this means
Is this means that ROS DNS server uses NextDNS as upstream resolver?
Anyway, DNS config property with IP (ROS IP?) of DNS resolver in [Interface] section of peer config can be set or hairpin nat for DNS in ROS firewall to avoid peer DNS override and also make sure that DNS is accessible from wg network.
