setup with CradlePoint & Netgear LTE modems
Hello, I am new to Mikrotik, but am loving it, except I cannot get this thing working right. My goal is to share the load between 2 LTE routers, that’s my only option for internet where I live.
About my setup: I am using a RB2011UiAS-2HnD
Ether1 has a Cradlepoint IBR900-1200M-B set to IP passthrough mode, I guess that’s their version of bridge (this connection is not always present)(5G capable)
Ether2 has a Netgear LB1120 set to bridge mode (LTE)
Ether10 is connected to my Switch, a Cisco SG500-52 (Outside in my garage, where most of my equipment is)
Whish is connected to my Swicth in the house Cisco SG500-28 (inside the house)
I was successful once by bonding ehter1 & ether2, but the packet loss was crazy and super slow. Most pages would time out before getting the info
I have tested both modems connected directly to a PC and the speeds are amazing, for me anyway, 76mbps and ping <1
I have tried every “Quickset” option and youtube tutorial I can find, and no luck.
I would like to be able to VPN from outside someday.
Any help would be appreciated.
Hmm, you not write a specific question ? It’s like note :).
About MultiWan : http://forum.mikrotik.com/t/moving-from-fail-over-to-using-both-wans/143145/2
But still you need some nth, pcc or own way to send traffic proper wan to do LoadBalance on MultiWan.
Write question :slight_smile:
I though it was explained. What do I need to do to make this work?
I though it was explained in #2.
General question then general answer is like that.
You must setup two gateway’s with differ distance. You can use Recursive Routing if you want.
Next you can just setup Route Rules or Mangle to send outgoing traffic to proper wan. If you want work with DNAT then you must have Public IP at ISPs and setup proper Mangle for In&Out, details in #2 ad2.
Next you can do some policy for LoadBalance traffic.
This forum is not for doing this for to you, you can do a MTCNA etc. courses, watch many toturials, read books, etc. MikroTik RouterOS not have a “QuickSet” to work with few WAN’s, this mean you must do that base at some howto/documentation etc. or read my #2 MultiWan url.
Looks like some MTU/MSS problems.
Export your config without password. I not know what you configure and in what way…
