Hello.
I have one point where I have to pay monthly per antenna installed. So is it possible to use several (at least 2) AP with one physical antenna ?
Or may be there are cases that looks line one antenna but have 2-3 panels inside ?
Thanx
Hello.
Thanx
Yes. It is virtualAP interface. But it will not provide additional separate radio with its antenna.
Sent from Android by Tapatalk.
Why multiple access points?
For cover a larger area?
If you want to obtain full coverage you will need to use an omnidirectional antenna which is not so good.
Several sector antennas are preferred.
To connect large number of customers from the same area.
Forget it. VirtualAP will not help you. Only using more sector antennas.
Multiple devices are needed.
Similarly several sector antennas to become a good performance.
There are tri-sector antennas that work well.
I have several in use where space is limited but 3 seperate sectors provides better isolation.
Can you recommend something ?
Good quality antenna.
Pacific Wireless is a top brand.
I hope they still available.
Howmatch simultane users you want?
