several interface problems on 5.0rc8 + intel Core i5+H67
Dear Mikrotik Dev Team,
My device have:
CPU: Intel Core i5-2400S 2.5Ghz Soket 1155
MB: INTEL DH67CF (OEM) LGA1155 PCI-E+DVI+HDMI+DP+GbLAN SATA RAID Mini-ITX 2DDR-III
Additional Network Adapter: Intel Gigabit Adapter Dual Port (OEM) PCI-E x4 10/100/1000Mbps
I am in real big trouble. My new installed device has very strange behavior…
  • integrated lan is not detected. Very bad for me
  • After i am issued interface print stats - than interface is going down. After some time - it come up again. Winbox - connected, but if I go to interfaces menu - active interface go down again.
  • Some other system cli commands turn interfaces down, for example - cpu information
Some details:
# DEVICE   VENDOR                                                        NAME                                                        IRQ
 0 03:00.0  NEC Corporation                                               unknown device (rev: 3)                                     10
 1 01:00.1  Intel Corporation                                             82576 Gigabit Network Connection (rev: 1)                   10
 2 01:00.0  Intel Corporation                                             82576 Gigabit Network Connection (rev: 1)                   11
 3 00:1f.3  Intel Corporation                                             Cougar Point SMBus Controller (rev: 4)                      11
 4 00:1f.2  Intel Corporation                                             Cougar Point 4 port SATA IDE Controller (rev: 4)            4
 5 00:1f.0  Intel Corporation                                             unknown device (rev: 4)                                     0
 6 00:1d.0  Intel Corporation                                             Cougar Point USB Enhanced Host Controller #1 (rev: 4)       7
 7 00:1c.1  Intel Corporation                                             Cougar Point PCI Express Root Port 2 (rev: 180)             11
 8 00:1c.0  Intel Corporation                                             Cougar Point PCI Express Root Port 1 (rev: 180)             10
 9 00:1b.0  Intel Corporation                                             Cougar Point High Definition Audio Controller (rev: 4)      3
10 00:1a.0  Intel Corporation                                             Cougar Point USB Enhanced Host Controller #2 (rev: 4)       11
11 00:19.0  Intel Corporation                                             unknown device (rev: 4)                                     5
12 00:16.0  Intel Corporation                                             Cougar Point HECI Controller #1 (rev: 4)                    11
13 00:02.0  Intel Corporation                                             Sandy Bridge Integrated Graphics Controller (rev: 9)        11
14 00:01.0  Intel Corporation                                             unknown device (rev: 9)                                     11
15 00:00.0  Intel Corporation                                             unknown device (rev: 9)                                     0
Please help…
Some addition detail: integrated lan chip is Intel 82579V.
Another news: after i turn off “Multi CPU” - the system goes without interface resets, but only pcie card. Integrated card - still not detected.
Do not use “latest” hardware.
No chance … At least now.
а так же не стоит юзать последнюю бету, на ней багов уйма.
Спасибо за конструктивный ответ…
А как же быть с новыми драйверами?
а чем тебя 7-я и 5-я RC версии не устраивают ?? там все теже драйвера, но работают они месяцами без проблем
Пробовал и 5 и 7 - теже грабли, если использовать указанное железо. При этом, на Core2Duo+chipset X58 - все нормально.
хмм.. а не пробовал в биосе отключить встроенную сетевую ?? или она нужна тебе ?
Я же написал - нет смысла ожидать поддержки самого нового хардваре (CPU: Intel Core i5 и соответственно motherboard + LAN к нему).
Я наступил на те-же грабли год назад. Купив “не ту” сетевую карту за 500$.
На вопросы (почти годназад) когда-же выйдет стабильная версия - был ответ “как-только так сразу”.
В результате уже почти год жду пока 5-ка станет стабильной.
Поэтому - не наступайте на мои грабли - Юзайте 4.16 и железо, которое его поддерживает.
ага, и при трафике в 1 гигабит 4.16 версия загнется уже на 300 мегабитах.. Может всетаки ковыряние в биосе даст результат. Нужно попробовать разные варианты..
Да как-то не хотелось бы отключать встроенную сетевую. И особенно я горюю, что пришлось отключить многоядерность… просто катастрофа… Даже не знаю что и делать-то…
this forum is in english, please switch to english
Sorry, but the initial questions was in english… Our conversation on russian was about new hardware and ROS5.
Could you please help me with my question?
I fell that this problem related to my http://forum.mikrotik.com/t/routeros-v5rc8/44336/71
After upgrade from 5.0rc5 to 5.0rc8, I don’t see interfaces in winbox, first time I was able to see them via ssh, but now I cannot see them. Some interfaces still works, some doesn’t.
загибается? а что такого появилось в 5.0 от чего не будет загибаться? Нам сейчас предстоит до 300 мбит прокачаться =)
Thanks for the info! Do you have any progress on your ticket?
I recived 5.0rc9 preview, same thing + now IP protocol doesn’t work =(
what you mean by that? IP is OSI layer 3, if it is not working anything else is not working on upper layers for example, ICMP, TCP, UDP
[test@MikroTik] > /ip address print
75   192.168.6.6/16     192.168.0.0     ether1
[test@MikroTik] > /ip route print
[test@MikroTik] >
Please create supout.rif file and send it to support
edit:
also, if you want to try - 5.0rc9 note that in e-mail as there where changes done to routing.
