Several MT's NAT problem
Our LAN:
(company server 10.0.0.10)<—>(10.0.0.1) Ether1-MT1–Wlan(10.0.1.1)<---->(10.0.1.2)Wlan1-MT2(10.0.2.1)-Wlan2(10.0.3.1)<—>(10.0.3.2)Wlan1-MT3(10.0.4.1)<---->Wireless Client<—>Office PC 10.0.3.3)
I use internal ip addresses with masquerade.
The problem:
I want to connect 2 PCs (10.0.3.3) and (10.0.2.1) to MS SQL server 10.0.0.10, when the first pc connected to sql server the other automaticaly disconnect.
If can anyone help me please write in the forum.
Thank in advance
Christos
I would guess then that SQL doesn’t like multiple connections from a single IP - seeing that they are natted.
In the example you’ve given however, you really don’t need to NAT - just a couple of static routes and you should be on your way.
C
