Sextant Bridge 2 networks
I have 2 Sextants (L3 license).
I need to transparant bridge to buildings.
How can I do this?
It is for temp. use. Our SXT we use are going back for inspection and now I need a connection between these two buildings.
Try this.
http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks
Hi, thanks,
I found this document as well an try it but does not work. (sure I have done somthing wrong.
Step 3 and for is not totaly clear for me.
If I do this:
3. Create wds interface on AP and add the interface to the bridge in WinBox
I don’s see the wds1 in the wireless tables.
To make a transparent wireless bridge do the following:
on one sextant set the mode to Bridge
on the other set the mode to station-bridge
on both ends add a bridge and put the eth and the wlan in the bridge
if you want to pick up an IP for management add a dhcp client to the bridge interface
or set a static IP on the bridge
Hope that helps
Nick.
Thanks for your reply.
I have the link up and running now but only the speed is slow.
I have a max troughput from 2 MB/s till 2.5 MB/s
I changed frequence
I alligned the device.
What else can I do?
