I have 2 SEXTANT G-5HnD and connect tham to an RB951-2HnD
They are connected at 100Mb full duplex but not on 1Gb full duplex.
Do they really have a Gb NIC??
All other devices I connect to the RB-951-2HnD show me a 1Gb connection but the SEXTANT G-5HnD not.
I need more speed. Now I can not use the max speed for the 801.11n.
Hi, thanks for you quick reply,
I wil try this in the evening. I’m at my work now.
Maybe you have a point.
I have Gb power injectors at home so I will try this in the evening.
Now I have connect them with the PoE I recieved with the 2 devices. A small cable with a RJ45 male and femail and one conector for the poweradapter.
But let you know what the result is I I change them.
I have changed the POE injector cables.
Now it shows a speed of 1 GB speed.
Strange but nice thing is that the wireless linkspeed is allso much higher now.
I now see TX 270Mbps RX 240 Mbps and before changing the PoE cable it was Tx 90Mbps RX 80 Mbps
I can not explain this but it is verry nice.
