SEXTANT G-5HnD MCS12-MCS13-MCS14-MCS15...? I dont find ???!!
Hi Everbody
I buy 5 pcs SEXTANT G-5HnD.
And I tested products nstreme protocol.
work only MCS0…MCS7
Max date rate 145Mbit
Stable: 136Mbit
I dont find MCS12…MCS23 !!!
This product have??? or naot have MCS12…MCS23 !!!
SEXTANT G-5HnD supports up to 300 Mbps data rate. Are both HT RX and TX chains enabled? Please provide you configuration. You can export it with the following command:
/interface wireless export
Also you can send supout.rif file to support@mikrotik.com.
Thanks dear sir.
I have de....rand brand wireless.
very nice mcs select.
I will work only mikrotik
I dont find mikrotik where can i select MCS.
[admin@ham] >> interface wireless export
jan/14/1970 01:55:29 by RouterOS 6.1
software id = 4L9B-XX62
/interface wireless
set 0 band=5ghz-onlyn channel-width=20/40mhz-ht-above disabled=no frequency=5320
frequency-mode=superchannel hide-ssid=yes ht-ampdu-priorities=0,1,2,3,4,5,6,7
ht-guard-interval=long ht-rxchains=0,1 ht-txchains=0,1 hw-retries=15 l2mtu=2290
mode=bridge ssid=MikroTikVer tx-power=18 tx-power-mode=card-rates
wireless-protocol=nstreme
/interface wireless nstreme
set wlan1 disable-csma=yes enable-nstreme=yes framer-limit=3999
ykutlu, you must use “print advanced” to see this setting:
[admin@branded] /interface wireless> print advanced
0 R name=“wlan1” mtu=1500 mac-address=D4:CA:6D:60:E8:29 arp=enabled
disable-running-check=no interface-type=Atheros AR9300
radio-name=“D4CA6D60E829” mode=ap-bridge ssid=“normis” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2412 band=2ghz-b/g/n channel-width=20mhz scan-list=default
wireless-protocol=any rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
distance=dynamic tx-power-mode=default noise-floor-threshold=default
nv2-noise-floor-offset=default periodic-calibration=default
periodic-calibration-interval=60 dfs-mode=none wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
wmm-support=disabled hide-ssid=no security-profile=normis
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0
ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,
mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,
mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
ht-txchains=0 ht-rxchains=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192
tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30
nv2-security=disabled nv2-preshared-key=“” hw-retries=7
frame-lifetime=0 adaptive-noise-immunity=none
hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced
multicast-helper=default multicast-buffering=enabled
/interface wireless print advanced
0 R name=“wlan1” mtu=1500 mac-address=D4:CA:6D:9C:D4:85 arp=enabled
radio-name=“D4CA6D9CD485” mode=bridge ssid=“MikroTikVerici” area=“”
frequency-mode=superchannel country=no_country_set antenna-gain=0
frequency=5320 band=5ghz-onlyn channel-width=20/40mhz-ht-above
scan-list=default wireless-protocol=nstreme rate-set=default
54Mbps
basic-rates-a/g=6Mbps max-station-count=2007 distance=dynamic
tx-power=18 tx-power-mode=card-rates noise-floor-threshold=default
wmm-support=disabled hide-ssid=yes security-profile=default
ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-guard-interval=long
ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192
ht-amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2
nv2-qos=default nv2-cell-radius=30 nv2-security=disabled
nv2-preshared-key=“” hw-retries=15 frame-lifetime=0
adaptive-noise-immunity=none hw-fragmentation-threshold=disabled
hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
rate-selection=advanced multicast-helper=default
