SEXTANT G VS DYNADISH 5
I don’t get it.
For 11 years I have been running SEXTANT G between my 2 towers and was very fast at speed and when looking at the Registration table under wireless it was at 144/144 mbit.
Now after just over 11 years I have bought 2 dynadish 5 and replaced with SEXTANT G and I am not achieving the speed I have been driving for the last 11 years :slight_smile:
PT I have set up dynadish run NV2 with 5-AC and set MHz to 20/40 Ce
I have not set up any vlan or router just a simple p2p network and nothing else.
the signal is fixed -52 -52 and I run a bandwidth test over tcp single recerive it is at about 40 40 to 50 Mbit and send about 40 mit.
Can it really fit dynadish can’t anymore? After all, that’s far from what SEXTANT G has been running for the 11 years I’ve used them?
Regards
Jimmy
thats weird. i have tested 2 dynadish 5. from my house to remote site without line of sight. bad snr …about 30% and still get about 100mbit down and 80mbit up
Sent from my Moto G (5) Plus using Tapatalk
hmm any others there are running dynadish 5 ?
