SEXTANT Polarity Issue
Has anyone else recently taken delivery of SEXTANT 5Ghz units and found they cant connect to base stations that are radiating in the vertical plane until they rotate the SEXTANT device into the horizontal position?
I have tried a couple from the latest batch we received and none of them connect unless you rotate into the horizontal plane, this wouldnt be a problem if they designed the bracket to allow mounting horizontally to a vertical pole.
:laughing: :confused:
Have you got both chains enabled? I have no problems connecting Sextants to vpol sectors..
That fixed it, thanks for your help taduikisโ€ฆ
Saludos
