I have tested and discovered that SFP-10G-LR SFP+ modules don’t work with the CRS226 series switches.
Keefe
Keefe
I am currently using a SFP-10G-LR in a CRS226, linked toward a CCR. This setup has worked fine the last 6-8months.
The SFP+ is a Fiberworks module, but is Cisco coded(was originally supposed to be used in a Catalyst 4500-e switch), but works fine with all Mikrotiks I have tested it with.
Regards
Please post printouts from commands:
/interface ethernet print detail where name~"sfp"
and
/interface ethernet monitor (interface)
[admin@ehq-sw1] > /interface ethernet print detail where name~"sfp"
Flags: X - disabled, R - running, S - slave
0 S name="sfpplus1" default-name="sfp-sfpplus1" mtu=1500 l2mtu=1588 mac-address=4C:5E:0C:9B:C4:DE
orig-mac-address=4C:5E:0C:9B:C4:DE arp=enabled auto-negotiation=no
advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full full-duplex=yes tx-flow-control=off
rx-flow-control=off speed=10Gbps master-port=ether1 bandwidth=unlimited/unlimited switch=switch1
sfp-rate-select=high
1 S name="sfpplus2-gfs-xe" default-name="sfpplus2" mtu=1500 l2mtu=1588 mac-address=4C:5E:0C:9B:C4:DF
orig-mac-address=4C:5E:0C:9B:C4:DF arp=enabled auto-negotiation=yes
[admin@ehq-sw1] > /interface ethernet monitor sfpplus2-gfs-xe
status: no-link
auto-negotiation: done
advertising:
link-partner-advertising:
sfp-module-present: yes
sfp-rx-lose: yes
sfp-tx-fault: no
sfp-connector-type: LC
sfp-link-length-9um: 10000m
sfp-vendor-name: OEM
sfp-vendor-part-number: SFP-10G-LR
sfp-vendor-revision: A
sfp-vendor-serial: CLS10281932
sfp-manufacturing-date: 14-01-10
sfp-wavelength: 1310nm
sfp-temperature: 44C
sfp-supply-voltage: 3.348V
sfp-tx-bias-current: 0mA
sfp-tx-power: -7dBm
Here’s one side. I have to get the other in a little bit.
In printout we can see that module for some reason ain’t receiving incoming signal from device that is connected on the other side. Printout from other device could probably show more. Also please mention what device model you have on the other side of link.
