Hi all,
I bought a GPON lxt-010S-H and push it to my router rb5009.
The problem is, now, i don’t hear the click and i push down the metal bar !
Impossible to remove the SFP module from my router.
Someone have an idea ?
Thanks a lot
Hi all,
Thanks a lot
Hello
Try to press with a bit more force the metal bar, maybe it needs a little more to release the small triangle (which locks the module in the cage)
