Hi to everyone , i have an issue when i try to connect Router 4011 with any device with SFP , i use the Mikrotik DAC cable , code=S+DA0001
My other devices is CRS106-1C-5S , CRS112-8G-IN
All of them have default configuration , on router i change the ip address in case on conflict between MIkrotik Devices.
Can someone tell me , where is the wrong ?
Thank you!
Use another DAC.
https://mikrotik.com/product/s_ao0005
5m SFP+ 10Gbps Active Optics direct attach cable. This is highly cost-effective way to connect two SFP/SFP+ devices for very short distances, within racks and across adjacent racks. It works with all our products with SFP/SFP+ ports, including new RB4011 series (> RB4011 series are not compatible with our passive direct attach cables S+DA0001 and S+DA0003> )
https://wiki.mikrotik.com/wiki/MikroTik_SFP_module_compatibility_table
Notes:
RB4011 – Only active Direct Attach Cables (MikroTik S+AO0005) are supported. Passive DAC (MikroTik S+DA0001/S+DA0003) are not supported.
